rear end codes
Old Jan 8, 2010 | 01:09 AM
srosscamaro@aol's Avatar
Car: 85 trans am
Engine: 5.7 goodwrench edelbrock everything
Transmission: t-5 stage 2 clutch
Axle/Gears: 3.27 posi
rear end codes
HELLO IM TRYING TO DECODE THE REAR END IN MY 82 TRANS AM CFI CAR IT HAS DRUM BRAKES BUT I THINK ITS A POSI IT HAS THE LIMITED SLIP FLUID ONLY TAG AND WHEN I TURN THE YOKE BOTH AXLES TURN THE SAME DIRECTION .
BASILY IM TRYIN TO FIND A BRECK DOWN OF WHAT THE NUMBERS STAMPED ON THE REAR END MEAN I DONT HAVE THE RPO STICKER IN MY GLOVE BOX
THE NUMBERS ON THE REAR ARE GM3 22511175N E A MOON SLIT IN HALF SYMBLE AND 05 AFTER THAT
Old Jan 8, 2010 | 07:30 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: rear end codes
Originally Posted by srosscamaro@aol
HELLO IM TRYING TO DECODE THE REAR END IN MY 82 TRANS AM CFI CAR IT HAS DRUM BRAKES BUT I THINK ITS A POSI IT HAS THE LIMITED SLIP FLUID ONLY TAG AND WHEN I TURN THE YOKE BOTH AXLES TURN THE SAME DIRECTION . BASILY IM TRYIN TO FIND A BRECK DOWN OF WHAT THE NUMBERS STAMPED ON THE REAR END MEAN
Axle tube codes in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
Since the fluid probably hasn't been changed in recent memory, perhaps popping the diff cover and taking a peek would be the easiest and most reliable way of determining what's what (there are pics of the various kinds of limited slip in the above link).
JamesC
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
mizz0313
Aug 12, 2015 06:45 AM
