Transmission chosing help
Old Jan 10, 2010 | 10:32 PM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
I have been searching for a donor car to do a t-5 swap with my 92 RS. I have ran out of time almost. I have been informed tonight that I can use a 4th gen V6 t-5. They said that everything will interchange. Is this true? Can I really use a 4th gen V6 t-5 to do my swap? If this is true what else will I need to get shifter plate, rear end, drive shaft? Please help. Thanks.
Old Jan 11, 2010 | 12:05 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Transmission chosing help
I think that v6's are still 10 spline...you need a 26 spline.
82-02 f-bodies all use the same size driveshaft.
I don't know what you mean by a rear end needed?? why would you need that? are you asking if you need to do a gear swap.....no.
Old Jan 11, 2010 | 12:21 AM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
The V8 auto have 2.73 gears and a V8 manuel has 3.08 gears. So the v6 wont work, and I need to keep looking.
Old Jan 11, 2010 | 12:27 AM
Engine: L98 494hp
well, not always.....there are different rear end gears in different cars....mine is a v8 auto and came with 3.23 gears.
Old Jan 11, 2010 | 12:29 AM
camaro1992's Avatar
Car: 92 RS Camaro
Engine: V8 5.0 TBI
So do I need to look for a v8 82-92 fbody?
Old Jan 11, 2010 | 12:47 AM
Engine: L98 494hp
for the tranny, you could do t5 from 82-92.....90-92 a little stronger (world class t5).
93-97 T56 six speed
TKO tremec 5 speed
ST-10 four speed
any of these will work. Some are direct bolt in....some require a little more time and money. stock t5 the cheapest.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
