wot 3000rpms shifts?!?!?
i have a rebuilt tranny with around 5000 miles on it with a shift kit and when i punch it it revs up to 3000rpms then shifts any ideas? i have tried to adjust line pressure no difference... it shifts from first to second around 5-10 with just regular driving which is no good
any ideas?
is a 700r4
any ideas?
is a 700r4
Car: '78 GMC Sierra Heavy 1/2
Engine: GMPP ZZ4 Q-Jet
Transmission: 700R4 Stage 2 w/Race Internals
Axle/Gears: 10 Bolt 3:42 Eaton
Re: wot 3000rpms shifts?!?!?
I'm no expert, just suggestions.
I assume this shifting problem is new and it shifted fine 5000 miles ago.
Check that your TV Cable is properly adjusted ( you said you checked line pressure ). Maybe it is hanging up inside the Cable Housing somehow? Unless you hooked a gauge up to it externally and checked line pressure while driving......
If you adjust the Cable to factory and feel it is not binding, pull the Governor and look for a broken Spring or Weight.
Sorry I don't have anymore ideas.
thanks for you ideas...
i adjusted to cable and same thing
it did kick a lot more when i first got it and i thought i had just got use to it but its not kicking nearly as hard now idk if thats normal or not
Car: 1991 Firebird Formula
Engine: 6.0 LQ4
Transmission: TKO600
its your govenor, the weights need to be changed, mine did the same thing after i had it rebuilt and beefed up. Took it back and told them they forgot to switch the weights for the govenor.
Pac J
May 17, 2020 10:44 AM
Damon
Sep 26, 2015 04:29 PM
