What rear axle should we run?
We picked up an 87 LT that we will be stuffing a centrifical supercharged 377 in, around 600 hp or so. We have a 700R4 set up for this but rear axle is the question. I had the 377/700R4 setup in my Monza TC years back and ended up with a narrowed Dana 44 but it's to narrow now and I don't think that it would hold for the camaro as there is more tire/pounds.
Can get a Fo** 9 in made for bolt in from Jegs and allready have a 3.50 geared trutrac center section. My son, however won't abide having non chev parts unless absolutly neccesary. Any Ideas anyone?
Thanks in advance!
Thanks in advance!
Re: What rear axle should we run?
There are 12 bolt rears for the 3rd gen. And you can tell your son that there is not a single FORD part on any aftermarket 9" rear, everything is manufactured by the aftermarket. Ofcoures the same goes for the 12", not a single bit of real GM in there.
There are bolt in 12 bolt, Dana 60 and 9 inch Ford rear ends for these cars. You could also try to find a Dana 44. There were some of these made, but they are kind of rare. The Moser 12 bolt starts at about $2225. You can get a Moser 9 inch housing and axle package for $990.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Tell him he's an idiot. If he only wants Chev parts, he's limited to a weak factory 10 bolt or an aftermarket 12 bolt. The factory also supplied a slightly stronger 9 bolt but it's not a chevy part. It's made by Borg Warner in Australia. Same goes for the rare Dana 44. An aftermarket 9" or Dana 60 is in name only. You can have a complete aftermarket diff and not have a single OEM part in it.
red90IROCls1
Aug 25, 2015 06:56 AM
