t56 swap almost done.. one question
Old Feb 17, 2010 | 09:35 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
I am almost done. Tranny is in, clutch is in and ect, but i cant get the torque arm on. Im going from a 700r to a t56, so the torque arm is susposed to be resuable, but i can not get this thing to bolt up. None of the holes are the same as the 700r. Can anyone help me with this??
Old Feb 17, 2010 | 09:37 PM
Drew's Avatar
Re: t56 swap almost done.. one question
You know the bracket for the torque arm is different on the T5 and T56 then the 700R4 right? You need the bracket from a T56 or T5.
Old Feb 17, 2010 | 09:46 PM
Engine: 383 Stroker
Transmission: t-56
Can you post a link to one?
Old Feb 17, 2010 | 09:52 PM
Drew's Avatar
I haven't got any idea where you'd buy one new. Maybe the dealer? It's just the metal bracket that wraps around the rubber torque arm bushing and bolts to the tail of the transmission. 700R4/4L60 have the bolts in a different pattern. The thirdgen T5 torque arm bracket looks close enough to me that it'll work. A 4th gen V6 T5 torque arm bracket might work too.
Old Feb 17, 2010 | 10:03 PM
Engine: 383 Stroker
Transmission: t-56
I dont really need a new one... the junkyard has an 86 camaro with a t5, ill see how much theyll take for the bracket. I already have a new polyurathane bushing, ill just swap it over. THanks homeslice
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
reiderz iroc
Aug 13, 2015 04:57 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
