T56 short throw shifter
Old Feb 18, 2010 | 03:53 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Im almost done with my t56 swap. My transmission has the shifter, but no shifter stick or ****. I have an extra **** so thats no problem, but no shifter stick. I cant find one to save my life. So these are my 2 choices now that im so limited on funds..
http://cgi.ebay.com/ebaymotors/Short...item1c1018e9a3
http://cgi.ebay.com/ebaymotors/99-00...item2555ff4165
Ive never had a short throw before, but what can they really hurt? I mean as long as its not plastic, it should do for a few months until i can get the pro right? Thanks
Old Feb 18, 2010 | 07:31 PM
Engine: 383 Stroker
Transmission: t-56
Re: T56 short throw shifter
boop
Old Feb 18, 2010 | 08:51 PM
Drew's Avatar
There's a couple different schools of thought on shifters. Factory shifters are usually intended to be more comfortable then anything else. By making the shifter lever shorter, the distance between shifts is reduced, resulting in FASTER shifts. But usually it's less comfortable and you lose leverage in the process. Just changing the lever usually has little real effect, other then putting the **** lower in the console.
Aftermarket shifters change the location of the pivot point, along with a slightly shorter handle to make for shorter shifts. Most also add positive stops so you don't end up damaging the transmission by over shifting.
If you're limited on funds, just buy a good quality shifter lever and save your money for an aftermarket shifter at a later date. The far east cheapo products off of Ebay are one step above burning your money.
Hotrodboba400
Dec 10, 2019 07:07 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
