5 speed z bar conversion.
Old Feb 22, 2010 | 06:21 PM
budget350's Avatar
Car: 87 iroc, 91 rs
Engine: 350 worked, 305
Transmission: 5 speed zbar setup. auto
Axle/Gears: 3:73 gears. stock
guys i got the 5 speed zbar setup and im just going to put in my car, ima pull my drivetrain and re do the motor again and jut have it th eway i want it. So i got the pedals, tranny, driveshaft, cross member, clutch, flywheel, flex plate, zbar setup and bellhosuing, and console. So how much work is it, etc etc thanks
how hard is the conversion.
Old Feb 23, 2010 | 02:37 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 5 speed z bar conversion.
WTF are you talking about here?
You're pulling your 700R4 to put in a T-5 5 speed right? Why not use a hydraulic clutch, rather than a z-bar setup? Does the T-5 you have even have the bellhousing setup for a z-bar?
Either way, i'd move heaven and earth to install a hydraulic clutch setup, even if I had to use a hydraulic TO bearing.... The z-bar and pushrod setup is JUNK for a million reasons...
Old Feb 23, 2010 | 06:02 PM
budget350's Avatar
Car: 87 iroc, 91 rs
well i have everything for a zbar setup and im low on funds so only reason for KEEPING the zbar setup. I have the whole conversion.
J-money
Jan 4, 2019 09:45 AM
neilb
Sep 15, 2015 05:06 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 6, 2015 06:23 AM
SG91camaro
Sep 5, 2015 10:27 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
