help with coasting downshifts.
Old Feb 25, 2010 | 02:04 PM
siduramaxde's Avatar
Car: 86 berlinetta
Engine: 383
Transmission: built 700r4
Axle/Gears: 3.42 zexel torsen
I just put a 383 in my car and rebuilt the 700r4 with a TCI kit. The trans shifts great when accelerating from a stop (firm, crisp, and timed right). However, when coasting from highway speed (4th gear, TC lockup) to 40-30 mph the car stays in 4th and won't downshift till below 30 mph. This causes the car to bog. When accelerating it doesn't shift into 4th till about 55-60 mph (which is good). The car did this same thing before the trans rebuild too. Is there a way to fix this? Currently I have 2.73 gears but in a couple weeks I will have 3.42 gears.
Rod
Old Feb 25, 2010 | 09:30 PM
Car: 86 berlinetta
Engine: 383
Re: help with coasting downshifts.
anyone????
Old Feb 26, 2010 | 05:50 PM
danandamy's Avatar
Car: 86 Camaro
Is the TV cable adjusted properly?
Dan
Old Feb 26, 2010 | 10:49 PM
Mrs.Crasher0083's Avatar
Car: 88 Pontiac GTA and 4 Camaros
Engine: 5.7
Old Feb 26, 2010 | 10:59 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
a sticky governor could have easily been overlooked during the rebuild.
Old Feb 27, 2010 | 08:30 AM
Car: 86 berlinetta
Engine: 383
Tv cable is adjusted correctly. I thought the governor only controlled WOT shifts. The trans up shifts great. I wonder if it has something to do with the 2.73 gears in the rear end?
Old Feb 27, 2010 | 09:49 AM
the gear ratio shouldn't matter. you could have a t.v cable or linkage problem or manual linkage problem, checkball missing, wrong or mispositioned valve body/separator plate & gasket.
db057
Jan 10, 2020 08:55 PM
dmccain
South East Region
Sep 30, 2016 06:23 AM
racereese
Oct 3, 2015 03:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
Americanmouse
Sep 7, 2015 12:10 PM
