how do i tell what rear end option (G92)?
Old Mar 2, 2010 | 06:05 PM
cfoxworth's Avatar
Car: 1992 Camaro R/S
Axle/Gears: '95 Z/28 3.42 posi
Where is the info on what option the car had for the rear gears?
Old Mar 2, 2010 | 06:23 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: how do i tell what rear end option (G92)?
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Mar 2, 2010 | 06:42 PM
Drew's Avatar
The shortest answer I can give is this...
92 Camaro RS with a 305 TBI automatic would have come with 2.73's from the factory.
Old Mar 2, 2010 | 11:02 PM
cfoxworth's Avatar
Sorry, my message wasn't real clear. I know what I have but am foing to look in salvage yards and wanted to know how to easily tell what gears the cars had. Wanting lower gears for mine. Thx for the reply and help.
Old Mar 3, 2010 | 12:28 AM
Drew's Avatar
Check the SPID in the console (if it's still there, and correct to the car) and look for the G?? codes. GU6 = 3.42 GU5 = 3.23 There are other codes for gear ratios that were offered, but the differential codes start with the G. In general, 6cyl cars will have the better gear ratios, but they don't usually have posi or disc brakes. Some years/models the 350 TPI came with 3.23 or 3.42 gears, and some of the HO cars came with 3.73's. All of the LG4 and L03 auto cars will have 2.73 or 3.08 gears. 305 TPI autos are hit and miss, most have 2.73's. 305 TPI 5spds usually had 3.08 or 3.42 gears.
Of course all of that only gets you so far. The only way to know what's in the car now is to verify it yourself. You can mark the driveshaft and a tire and count revolutions. Or you can pop the cover and look for the stamp on the ring gear.
Most of the junkyards I used to frequent would write the gear ratio on the windshield, and on the rear end housing to make ID quick and easy, but I wouldn't trust those kind of marks explicitly. Double check yourself to avoid getting screwed.
Old Mar 3, 2010 | 06:22 AM
JamesC's Avatar
The RPO/G codes, axle tube codes, and gear stamp codes are all found in the link above.
JamesC
Old Mar 3, 2010 | 03:28 PM
cfoxworth's Avatar
Thx guys, I am still new to all of this and really apreciate the help.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
