TC lockup question
Old Mar 14, 2010 | 10:39 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
TC lockup question
The guy i bought the tranny from already had the painless kit installed but did not come with the external vacuum switch. Do I still have to pull the tranny pan and do all the wiring stuff over or should I just buy a kit and plug in the harness and finish?
Thanks, Chas
Old Mar 14, 2010 | 05:02 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: TC lockup question
If your sure it's been done correctly, then no - just connect the external wiring and new vac switch as needed. But that's the question - was it done and done correctly?
Old Mar 15, 2010 | 08:41 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
alright looks like ill be pulling the cover and taking a look.
Old Mar 15, 2010 | 10:51 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
As of right now i dont have the cash to buy a new painless unit but is it possible to hook up a manual converter lock? I just dont want to burn up this tranny on my way to school running on the highway.
Thanks, Chas
Old Mar 17, 2010 | 07:27 PM
Firebat's Avatar
Very possible to wire up a manual converter lock switch but I'm not sure how.
You can also wire up the vacuum switch, along with a relay, without changing out any parts inside of the auto transmission. I did this with my 700r4 setup I used to have:
https://www.thirdgen.org/forums/ltx-...-question.html
Bubbajones_ya
Aug 31, 2015 12:02 PM
someone972
Aug 30, 2015 12:52 AM
Eric-86sc
Aug 24, 2015 09:01 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
