TKO 600 speedo cable help
Old Mar 23, 2010 | 07:25 PM
brodysZ28's Avatar
Car: 1983 Camaro Z28
Engine: 383
Transmission: TKO 600
Axle/Gears: Strange S60
Ok, so the tranny has an electric sensor, but my car has mechanical cable... needs to be hooked up to pass inspection.
What are the options here?? preferably as least expensive as possible.
Thanks.
Old Mar 23, 2010 | 08:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: TKO 600 speedo cable help
the tko has a mechanical output too. It has a rubber plug in it when you recieve the trans, its almost at the end of the trans, and i believe the driverside
where did you get it?
Old Mar 23, 2010 | 08:50 PM
brodysZ28's Avatar
Engine: 383
ohhh awesome, I actually bought it used from a guy who was gonna put it in his mustang, so I sould either get an adapter from a place like fortes or get a stang speedo cable and cut in and attach it to my cars speedo cable?
Old Mar 23, 2010 | 08:57 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
not sure about the mustange cable idea, but FWIW, i have the mechanical adapter from fortes, it came with my trans, i dont know how it works or what its supposed to be used with. Its just some kind og adapter sleeve thing and a pin. I guess you have to swap gears on to it and use the f-body t5 sender?
Old Mar 23, 2010 | 09:03 PM
brodysZ28's Avatar
Engine: 383
hmm ok I will keep that in mind, wat did you end up doing? I need it done lk tomorrow so ima prolly just do watever is the quickest.
I thought the whole point of their adapter was that you can't use the T5 gear so they made an adapter? not sure though....
Old Mar 24, 2010 | 06:57 AM
brodysZ28's Avatar
Engine: 383
So i guess that the hole where the mechanical unit would go has no gear in there that it would mesh with. Did every tremec tranny they made have both a mechanical and electric output or just certain ones? I just took the guys word for it that its a 600 but it could be one of the 3550's.
However I found a few possibilities.
http://www.dakotadigital.com/index.c...rod/prd109.htm
Not sure if one of these could work.
http://www.abbott-tach.com/cablex.htm
Supposedly this should work.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
