questions on GM 9 bolt rear
Old Mar 25, 2010 | 06:13 AM
IROC_Z89's Avatar
Car: 89 IROC-Z
Engine: 350 tpi
summitracing.com shows no rebuild or gear sets for the 9 bolt. I have a 9 bolt with 2:77s but would like to put in 3:73s soon. Is it possible to change gears in the 9 bolt and if so where can i find the sets? Thanks
Old Mar 25, 2010 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: questions on GM 9 bolt rear
https://www.thirdgen.org/forums/afte...er-9-bolt.html
JamesC
Old Mar 25, 2010 | 09:07 AM
big gear head's Avatar
You can't put 3.73 gears in a 9 bolt with 2.77 gears. The 2.77 uses a 2 series differential and you need a 3 series for the 3.73 gears. You will need the differetnial from a rear end with 3.27 gears to install the 3.73. You can buy the differential new, but it is expensive.
hectre13
Dec 11, 2023 08:14 AM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
1nastygta
Aug 8, 2015 07:38 PM
