How much can the 700r4 withstand?
Car: 1988 Camaro IrocZ
Engine: Holley Stealth Ram 385 Stroker
Transmission: Redline Performance 700r4 Trans
Axle/Gears: Bulletproof 4thGen Ls1 SS Rear 3.73
I have the stock 700r4. How much Horsepower and torque can it handle without being modified or swapped out (#s?).
If it doesn't stand much over stock would i need to upgrade it and if so what would i upgrade it with (kit wise?).
Or, If i should upgrade to a better transmission what should it be and how much can it withstand? Be it mind i don't want to upgrade to a manual.
Thanks,
Sean
Thanks,
Sean
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: How much can the 700r4 withstand?
Cant really put a number on it, varies on mileage, torque, abuse, etc. Mine went out just below 400hp.
IMO, dont mess with it until it goes out. Then do a good rebuild.
Transgo kit might help prolong the life some. Main thing is to make sure the TV cable is always set correctly.
When the time comes to upgrade, rebuild, or buy a new one, call Dana at Pro Built Automatics
http://www.700r4l60e.com/
Also I would keep with the 700r4. The right components installed can make it a strong reliable trans with overdrive.
Dana's definitely the man to talk to when the time comes to rebuild/upgrade it. He offers street/strip kits that'll hold up to 650 HP and other kits that hold even higher if you're really building something crazy. Thread
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
