T-56 into 84 Camaro// Clutch Pedal setup
Old Apr 5, 2010 | 02:59 PM
houstonvett's Avatar
I will be installing a LT-1 T-56 out of a 1996 Z-28 into a 84 Camaro. I know the bell housing will bolt up to my 2 piece rear main seal SB motor just need to work on the clutch pedal setup. Will the pedals out of the LT-1 93-97 LT-1 Camaros work in the 3rd generation cars? Or do I have to use the 82 to 92 clutch pedals and fabricate up the slave cylinder for the throw out bearing in the T-56?
I saved this car from the crusher and plan to make it a cruiser. A nice new 400 HP SB and a 6 speed transmission should make this 84 Camaro into something worth driving. Glad I found a 3rd generation board for the Camaros, lots of good information here, houstonvett
Old Apr 5, 2010 | 03:03 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: T-56 into 84 Camaro// Clutch Pedal setup
There is a ton of info on this swap regarding the questions you have on this board. Search for T56 pedals. The general opinion seems to be that if you are using the LT1 T56 then the 4th gen pedals work best.
Old Apr 6, 2010 | 02:03 AM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Ive done the swap so i have personal experience. The 4th gen pedals will work, but you need to do some cutting and they will not work as well as the original 3rd gen pedals. I used the 3rd gen pedals and its alot better feel than the 4th. I swapped mine from an auto to t56.
EDIT: also you will need the $pecial centorforce flywheel so everything will bolt up. Cant use the lt1 flywheel on a 2 piece. And dont forget to get the t56 or t5 tourqe arm mount.
Old May 19, 2010 | 08:34 PM
19camaro84's Avatar
What all do I have to do to put one of those behind a 350sb from an 86 truck. beginning to end also...what are the best parts to use (clutch pedals, flywheel ect.)
devilschariot
Feb 25, 2016 03:08 AM
Drone358
Dec 10, 2015 08:16 PM
tonys91rs
Oct 10, 2015 03:31 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
