Stripped threads in trans
Car: 85 IROC Z
Transmission: TCI TH350 TCI 2400 STALL
Axle/Gears: 3.42 WORN OUT POSI
Hey guys I'm looking for some advice as to why my car has pulled the 2 bolts from the trans mount to the trans straight out twice. The first time it happened I re tapped it and as soon as I jumped on it they pulled out again. This time it got helicoiled and I had a mechanic look at it and he said theres not much meat left if it happens again I'm in trouble. My question is why is this happening? My car is not that fast. I don't want to have to replace the trans, I just got it like 18mths ago. Any suggestions?
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
Re: Stripped threads in trans
If it happens again change the tailhousing and move the tourqe arm to the cross member so it doesn't happen again .
Car: 85 IROC Z
Does it matter if the bolts aren't in the tailhousing? I swapped a th350 in and the bolts go into the case. Thank u. Sorry if this is a dumb question.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
sounds like the bolts are coming loose and then tearing out.
can you drill the hole larger and re-tap for a larger bolt?
Car: 85 IROC Z
Thanks guys its tapped and helicoiled let u know soon if it breaks.
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
