2.73 to 3.42 rear axle swap
Old Apr 16, 2010 | 08:15 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I just bought a 3.42 complete rear to replace my 2.73 with. It came from a '97 Z28 with disc brakes. Comes with everything but proportional valves. My question is this, will this rear end simply bolt up to my exsisting setup or will I need to replace mounting brackets, driveshaft, master cylinder, or anything else? First time I've tackled an axle swap so I need to know what to get to do this job. Can't afford to have her just sitting there waiting on parts.
Old Apr 16, 2010 | 08:41 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 2.73 to 3.42 rear axle swap
The rear is a straight bolt-in. The master and drive shaft are fine. Swap the combination valve for the first-design 1LE valve. You'll need the first-design parking brake cables and a change in speedo gears if you wish the speedo to read correctly. More info toward the bottom of the link below:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 16, 2010 | 08:58 PM
Engine: 350 S/B
Thanks James for the much needed info.!!
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
