Transmission mount broken, can't locate correct part
Old May 30, 2010 | 10:55 PM
h3adrush's Avatar
Car: 89 base firebird
Engine: 2.8
Well my transmission mount broken in half, i went to multiple parts stores, and the only thing that they had were square and round rubber mounts with a threaded post coming out of one end and a metal braket molded into the rubber with two holes on the other end.
These tranny mounts are completely different from mine, mine has two metal brackets a rubber/cast metal body [which broke] , a round sheet metal cap on the bottom and was oil filled. Any ideas ? And yes this is the component that the tail of the tranny mounts to and the cross member mounts to the bottom of it. thanks
o btw: its an 89 2.8l t5 5 speed, and i will post some images asap
Old May 31, 2010 | 06:38 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Transmission mount broken, can't locate correct part
You're describing an OE mount that wasn't seen long on our cars--and is very expensive to replace ($200 or so, IIRC). The easiest bet is to simply purchase a T-5 or 700R4 cross member, which uses the standard mount, and bolt it in. I doubt you'd be out more than $30 or so.
JamesC
Old May 31, 2010 | 02:48 PM
h3adrush's Avatar
Engine: 2.8
ok thanks
Old May 31, 2010 | 05:11 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Note that the '90 - '92 3.1l V6 cars used a two piece cross member. This may work better for your 2.8l engine. Helps smooth the vibrations. There is the main cross member. Then another that is above it mounted on rubber donuts. With the tranny mount then between the trans and the upper cross member.
RBob.
Old May 31, 2010 | 08:05 PM
JamesC's Avatar
As well as many other models, my 85 Iroc for example. Below is a pic of the secondary cross member with poly, but rubber for the secondary mount may still be available from GM:
https://www.thirdgen.org/forums/atta...ber-mounts.jpg
JamesC
Old Jun 1, 2010 | 11:55 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally Posted by JamesC
Yep, that's the one I was referring too. Didn't realize that GM used them for earlier/other f-bodys. Which is a good thing as it should make it easier to find.
RBob.
jhawkeye
May 25, 2022 06:33 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
1nastygta
Aug 8, 2015 07:38 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
