What manual transmissions fit in 83 camaro
Old Jun 11, 2010 | 11:36 AM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
Hey guys,
I purchased a camaro last year. I was driving it for a while and my transmission is gone. My father in law owns a salvage yard but all the systems say the only tranny's that work are the 3rd gen camaro and firebird.
I have been looking for about 4 weeks for a transmission but none available close by. What other manual transmissions would fit in our cars? I and my family have extensive fabrication experience but any ideas on which would fit easiest?
thanks in advance
Old Jun 11, 2010 | 12:38 PM
91350rs's Avatar
Car: 91 camaro RS
Engine: superchargered 350
Transmission: t56
Axle/Gears: 4.10
Re: What manual transmissions fit in 83 camaro
you can use a t56 out of the lt1 camaro. it requires some fabrication but if you have experience its not bad
Old Jun 11, 2010 | 12:54 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Money and time can make almost anything fit.
Old Jun 12, 2010 | 08:51 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The Super T-10 is a realistic swap. The preferred version, to my mind, was used in the '80 Z28 and the '80-'81 LG4 Trans Am. You'll have issues with mounting the torque arm, and rigging a clutch release mechanism, and there may be an issue with the slip yoke and driveshaft, but if you can get a not-bent driveshaft from the donor cars I listed, you can just get it shortened about 7", and re-balanced, problem solved.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
kyleb24
Aug 15, 2015 08:24 AM
