Blazer 700R4?
Blazer 700R4?
Anyone know the differences between the camaro 700r4 and the blazer 700r4? Was just wondering, because if I buy one, I am wondering what the effects will be with gearing, etc. More torque? Slower 0-60 times?
Thanks =)
Thanks =)
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Blazer 700R4?
Well....
Is it a 4.6L Blazer? If so, then you will have less clutches in the trans and it will burn up with any sort of power behind a V8. But, it will physically bolt up to a V8. Unless there is a V8 conversion done to the Blazer, the factory trans will not last behind a V8.
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: Blazer 700R4?
Well....
I HAVE YET TO SEE A 4.6L BLAZER..........
TAKE SOME PICTURES FOR ME
Car: 1988 iroc-z
Re: Blazer 700R4?
most blazers are 4wd,and if so the output shaft and tail is wrong,unless your camaro is also 4wd.
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
