96 T56 questions, take a look and help
Subscribe
Jul 3, 2010 | 05:23 PM
I have a 92 car with a 96 T56 install by the previous owner... the clutch engages way too high for my liking, it engages about 1/2" from letting out the clutch all the way, so im going to make the master adjustable from a "how to" i found here..
my problem/question is this... i know how to remove the master.. but the slave seems weird. I know that its held in by those 2 bolts on the driver side in the trans tunnel... but when i removed those 2 bolts, the slave seems to push itself out, i went to remove it but it seems stuck or still attached to something in the bell housing...
what am i missing here? how do i remove this slave, also how does it reinstall? thanks for the help.
Reply 0
Jul 3, 2010 | 08:18 PM
Re: 96 T56 questions, take a look and help
Should be just the 2 nuts and it will pop right out.
Reply 0
Jul 3, 2010 | 09:27 PM
the rod off of the slave might be seized to the fork. But has stated, after those 2 bolts are removed, it should come out.
Reply 0
Jul 4, 2010 | 02:30 PM
installation reverse from removal? anytihng special to installation?
thanks guys
Reply 0
Jul 7, 2010 | 12:04 AM
Just make sure you fork is in place and have the ball end of the slave rod on the fork, not much to it.
Reply 0
Subscribe
