700R4 won't move!!!!
Old Jul 12, 2010 | 02:59 PM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
Transmission: Built 700R4
Axle/Gears: Weak 10 Bolt/3.23
I recently finished my BBC swap on my 83 and am now having issues with my tranny. I bought a built 700 from a guy with a 2600 stall TC. No problems getting it in. Now that my motor is running great now my tranny is not. I can shift into all the gears with no issues but when in drive it's like the tranny is in neautral. I can give it all the gas in the world but still doesn't move. The TC lockup is not hooked up since I pulled my ECM, could this be why it isn't working? The car will move a little but when in reverse but won't pull forward. No drop in RPMs when cycling through the gears either. Anyone got any ideas?
Old Jul 12, 2010 | 03:26 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: 700R4 won't move!!!!
ok the lock up will not stop it from moving. what about the tv cable. is that hooked up correctly and working.
Old Jul 12, 2010 | 03:44 PM
jtraynor86's Avatar
Car: 1983 T/A
Engine: 454 BBC
I am pretty sure the TV cable is hooked up right. Pardon me if I sound ignorant but is there good way to check that. I have the right TV bracket for my holley carb.
Old Jul 12, 2010 | 05:12 PM
one92rs's Avatar
Car: SOLD!!!!!
quickest way is to reset it per the instructions. push the button in and shove it all the way back in. then get in the car and floor it a few times. then see if that helps out.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Fronzizzle
Sep 8, 2015 12:10 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
