stock 91 rs rear end questions
Old Jul 17, 2010 | 03:03 AM
dustin.carter2's Avatar
Car: 91 camaro rs
Axle/Gears: stock 10 bolt
Will the stock 10 bolt 7.5 in rear end hold up to 600hp with a rebuild. Im looking to make a street strip car out of it.
I plan to use
Moser or Alloy usa 28 spline axles
Powertrax no slip differential
regearing the rear end
Upgrading the lower control arms,panhard bar, torqe arm, and shocks/springs
runing 15x8 with 275/60/15 DOT drag tire
and ofcourse c clip eliminators
or is this a waste of money
also if it is worth it. what gear does everyone recomend running a built 355 175 shot on the bottle and powerglide w/4500 stall trans break?
Old Jul 17, 2010 | 09:07 AM
big gear head's Avatar
Re: stock 91 rs rear end questions
No. If you put sticky tires on it you will break it. If you only run street tires then it might last a while. I recommend that you pass on the Alloy USA axles. They sometimes require modifications to make them fit.
Old Jul 20, 2010 | 08:01 PM
Car: 91 camaro rs
Will a ford 8.8 fit with some modifications i have one just laying around i got for free. It came out of a 1987 ford f-150
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
