V6 transmission
Car: 1988 Camaro Sport Coupe
Engine: 305 Non Computer Edlebrok Carb
Transmission: Turbo 350
Axle/Gears: Original ones that came with car
V6 transmission
Will a transmission from a 2.8v6 fit onto a 305? if not what is the differences in the v8 and v6 ones?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: V6 transmission
The bellhousing is different as the bolt pattern on the back of the engine is different. The input shaft spline count is different. The gearing ratios are different. Yes it can be made to physically work if you use a V8 bell housing and a V6 clutch, but its not worth the hassle.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
