Rear end question
Old Aug 4, 2010 | 02:34 PM
bocaj25's Avatar
Rear end question
I have an 88 camaro with stock rear end if i were to buy just a ring and pinion set ( 3.73) would i need to change the "carrier" and how do you figure out which rear end you have either (8.5 IN) or (10 IN.)
thanks for the help
Old Aug 4, 2010 | 03:01 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Rear end question
You have a 10 bolt 7.5 rear end. No need to change the carrier for a gear swap. Only time you have to worry about the carry is when you are buying the gears becuase they have 2 series and 3 series gears. Do you know what gears are in it now ?
Old Aug 4, 2010 | 03:05 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
thanks for the help
I would suggest a lot of reseach. First, find what you have in your cars rear axle. Right now you DO NOT have 8.5" or 10". All 3rd gen cars came with a 10-bolt 7.5/7.625 dia gear or 9-bolt 7.75 dia gear. Again you can't think about gear change until you know what you have and in your case add a lot of money.
Old Aug 4, 2010 | 03:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link will provide info that may prove useful:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 4, 2010 | 07:44 PM
big gear head's Avatar
You MUST know what you have now before you buy any parts. You must figure out if you have the 7.5 10 bolt or the 9 bolt rear end. Then you must know what gear ration you have now. Then you can figure out what parts you need. When you get the gears be sure to get a good installation kit too. And buy good quality parts. Don't try to save a few bucks on bargan brand junk.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
