T56 clutch choices...help?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
I'm working on an L98/T56 swap and I'm looking for a new clutch setup, I want something that's gonna grip well and last, I've got a luk clutch on my t5 right now and its a pos. It slips when I beat on it and I did the break in perfectly, surfaced flywheel adnd everything, my motor is tired and I want something a lot better for my new motor but there's a million choices and I wanted to see what other people have and are satisfied with, I was looking at ram and zoom clutches on jegs, they're reasonably priced but I don't know their reputations, I've got a centerforce flywheel with the tranny too, running an lt bellhousing so it'll have to be an lt style clutch correct?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: T56 clutch choices...help?
really? Nobody has an opinion?? i gotta get this thing rollin, post up your choices please
TIA
TIA
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
i have some interest in this as well here is an evening bump good luck
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
i have a centerforce dual friction in mine held up a long time but let go at the track doing 5600 launches there are alot of companies i'm gonna try a SPEC clutch this time yes you still have to run the lt clutch the flywheel you got with the tranny is that for a 1piece or 2 piece motor?
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Id love to get one but I'm already in deep with my wife for takin on a full build and t56 swap lol I was thinkin of toin with zoom I just need something better than my luk clutch, this thing is a piece I'm not impressed lol maybe zoom will hold up, no real track time in the future unfortunately, I just had a daughter and she's not allowed at the track lol
Its going on a 1 piece L98 block too
bigjay89gta
Oct 15, 2015 08:04 AM
