Spinning Shifter.???
Old Aug 13, 2010 | 06:13 PM
91_fbird's Avatar
Car: 91 Pontiac Firebird
Engine: SMall Block 350 TBI
Transmission: 5-Speed
Axle/Gears: Stock(for now)
This may sound wierd but its driving me nuts. I have a 91 firebird, 350 EFI and a 5-speed transmission. It shifts fine......but for some reason my shifter can turn...not just the **** but the bar that goes down into the shift boot. I have tried rotating it right in hope of tightening it but no difference....i cn also pull up on it but i dont give it too much in fear of removing it, therefore crippling my car temporarily which i cant afford to do.
.....any idea or suggestions...or anything?
Old Aug 13, 2010 | 06:32 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Spinning Shifter.???
take the consol shifter plate off and see whats the matter. I dont think the handle screws together, so im unsure of whats loose.
Old Aug 14, 2010 | 01:53 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
You'll have to take off the lower shift boot too, there are like 9 screws holding it onto the transmission tunnel.
Sounds like the bushing/isolator for the shifter is worn, the thing that separates the shift handle from the "base" that bolts to the transmission and holds it in place. It's been a while since I had my shifter out so I don't remember it perfectly, but if I'm imagining it correctly it sounds like that's been worn a lot, and is allowing much more play than it should.
Take the shifter off, and check it out. Has it gotten worse over time?
Old Aug 14, 2010 | 12:10 PM
91_fbird's Avatar
No i dont believe it has. It doesnt effect my driving but i knoow that its not supposed to do that n i hate wen things dnt function. If i remove the console i should have access to that rubber boot with the nine screws in it right?
Old Aug 14, 2010 | 12:48 PM
If I remember correctly you should. 6 torx head screws to remove the console plate, and 9 screws below that for the boot. Then four 13mm bolts holding the shifter on.
You'll probably want to take the shifter **** off, so you can move the console plate out of the way and all
sheachopper
Jul 31, 2019 11:27 AM
gord327
Sep 29, 2015 10:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
jer4251
Sep 27, 2015 09:52 PM
jer4251
Sep 16, 2015 11:29 AM
