Missing some manual conversion parts
Old Aug 17, 2010 | 06:42 AM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
Aside from the big thing like the tranny (although I've got a lead on one), I'm missing the clutch reservoir bracket and the reservoir itself. Does anyone have a bracket that they'd be willing to part with?
How about the reservoir itself? Can I even get a replacement? Is the line going to the master cyl anything special?
Old Aug 17, 2010 | 07:49 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: Missing some manual conversion parts
I just went to a junkyard. They are easy to find around here. Once you clean the bracket and resivoir up, they look brand new and cost me about $10. The line going to the master is just rubber hose. Nothing special.
Old Aug 17, 2010 | 08:45 AM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
PLEASE don't use just any rubber hose on this line. Brake fluid will dissolve most common rubber hoses and you'll ruin your master and slave seals in short order.. The hose MUST be brake fluid compatible....
Old Aug 17, 2010 | 09:45 AM
built91Z28's Avatar
Woops, we may have a problem
Old Aug 17, 2010 | 11:39 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
How about the reservoir; does anyone make a new one?
Old Aug 17, 2010 | 11:53 AM
85MikeTPI's Avatar
Any new reservoir should work, the only difference would be how it looks and how it mounts. You can even use fancy motorcycle brake reservoirs they sell, if you want some bling..
1992 Trans Am
May 10, 2023 07:19 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
