Tranny cross member nuts in frame striped. Need help on how to replace them.
Car: 86 Camaro
Engine: Blown 383 w/NOS
Transmission: Glide
Axle/Gears: Moser 35 spline w/325 gears
I have an 86 Camaro and the the nuts that are in cased in the frame 2 of them are striped and I need to replace them. Can anyone give me points on the best way to replace them? Thanks for your time.
Car: 87 Trans-Am, WS6
Engine: 5.0 TPI
Axle/Gears: 4.10 Posi
Re: Tranny cross member nuts in frame striped. Need help on how to replace them.
Mine also striped so I replaced all 4 with Helicoils. I think they are 10mm but take one bolt to the autoparts or hardware store to match up the threads. The kit is the way to go.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
typically what done is you drill out the captured nut to a slightly larger size, and re-tap the hole. I think 7/16 is what usually used, not positive.
Car: 87 IROC-Z
Engine: 383 HSR $8D
I have one or two tapped out for a 7/16...been holding great for years. Helicoil might be sketchy due to the lack of super long thread engagement(typically I think of helicoils for cast type parts)...but if its working for this guy it must work...I just never thought much about it.
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 5, 2015 07:57 PM
