help with flywheel for t56
Car: 86 trans am
Transmission: T 56
I need to know what flywheel will fit a early 2 piece rear main seal crank and a t56 transmission.
I have a T56 flywheel from a 94 firebird but the bolt pattern is too small.
The car currently has a t5 in it, so I do have those parts.
Is there a certain clutch that fits this if I use the t5 flywheel? Is that possible?
What are my options?
Car: 91rs
Engine: 6.0
Transmission: 4l60e/3600 vig stall
Axle/Gears: 3.73 9 bolt
Re: help with flywheel for t56
http://www.summitracing.com/parts/CTF-700107/ buy one of these.
then use an lt1 t56 clutch. you also need the hydraulics for the lt1 clutch.
last time i bought one of these it was around $250, damn they went up in price!
Car: `86 SS / `87 SS
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
Quick story: a friends car has 400 , LT1 T56, a Spec 2pc LT1 flywheel and LT1 clutch and is using the balance plate. The starter wasn't engaging when the T56 parts went in. I figured it may have been the balance plate. Nope, just a crappy new Autozone LT1 starter.
Car: 86 trans am
Transmission: T 56
It is just a small block 350 strocked to a 383.
I was just hoping for a cheaper way out of this.
Thanks for the help
Thanks for the help
monte87cortez
Sep 26, 2015 08:10 PM
