LS1 Rearend
Old Aug 30, 2010 | 07:50 PM
AKATDOG's Avatar
Car: 84 Z28
LS1 Rearend
i just got all the brackets for the e-brake and brake lines, just not sure where they go, if anyone has pictures of a ls1 rear setup would be nice...
im also looking for the custom e-brake cables i need for the ls1 swap on a 3rd gen, hawks third gen has a set of cables for a lt1/ls1 swap but i thought the 2 setups are different??
can someone clarify because ebmiller here on TGO makes 2 different sets of cables one for the LS1 swap and one for LT1/1LE swap...
Old Aug 30, 2010 | 08:09 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LS1 Rearend
if you have a rear brake setup from a 98-02 4th gen, you need the ls1 style cables that ed has, if you have a 93-97, you can use the other lt1 style, but i thought the stock pbr disc parking cables would work with them?
Old Aug 30, 2010 | 08:22 PM
AKATDOG's Avatar
Car: 84 Z28
Re: LS1 Rearend
i switched from a drum setup to a 98-02 ls1 setup, Hawks 3rd gen parts sells a cable for a ls1/lt1 swap but im wondering if it will work or not before i order it...
ebmiller has 2 different cable one for ls1 and one for lt1/1le but been trying forevr to get them from him...
Old Aug 30, 2010 | 09:02 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: LS1 Rearend
i dont know about hawks, but if its marked a conversion cable, it will probably work. have a link?
as for ed, i have his ls1 conversion cables and they work great.
Old Aug 30, 2010 | 09:13 PM
AKATDOG's Avatar
Car: 84 Z28
Re: LS1 Rearend
this is hawks http://www.hawksthirdgenparts.com/li...ebird-1-2.aspx
but ive also been told there 2 different cables for ls1/lt1
loud91rs
Oct 5, 2015 10:05 PM
dusterbd
Sep 29, 2015 08:40 AM
