stall recomendation?
Old Sep 4, 2010 | 11:54 PM
xdsone's Avatar
i have an 86 trans am that will have a tpi vortec 350 and a comp cam xr258hr cam,30# bosch III injectors, shorty headers,no cats, flow master 80. what stall speed do you recomend? how many splines do i have i think i counted 27 but im not sure . its kinda awkward counting them wile the trans is in the car.
Old Sep 5, 2010 | 12:02 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: stall recomendation?
Thats a very small cam. I wouldnt go much more than 1600-1800. Although I would probaly just stay with a stock convertor, as I believe it stalls close to this already.
Old Sep 5, 2010 | 12:12 AM
xdsone's Avatar
Ok thanks I'm going to try programming the evidence my self so I didn't want too muchof a cam to start with. Anyone know what kind of gears I have in the rear I think its 3.73 or 3.23 I don't remember ive been burnt out on this engine build its my first. What gears do u all recommend?
Old Sep 5, 2010 | 12:19 AM
built91Z28's Avatar
I'm guessing you have a 700R-4. I'm also assuming by the mild motor build this is either a daily driver or just a fun cruiser not meant for racing. Given that, I think 3.42 (if you have a 10 bolt. Not sure whats available for 9 bolt) would be decent. The 700 has a good first gear ratio so you dont need tons of gear to get it to leave nice. You could go to 3.73's though. I think the 3.42's would be the best mix of leaving nicely, and cruising at lower rpms on the highway. With that cam you wont need to rev it much. It shows the power band ending at 5000 so you can get away with low cruise rpm.
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
