T56 use T5 flywheel?
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
I just swapped my T5 but have an opportunity to get a T56 - Do I need an LT1 flywheel or will V8 T5 flywheel work?
Thanks!
Thanks!
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: T56 use T5 flywheel?
need a t56 flywheel depnediong on what motor 1 piece will work with the factory t56 FW 2 piece you need an aftermarket one
Axle/Gears: 3.23:1
The T56 clutch requires a different flywheel from the T5. Since you've got a 1 pc RMS you can use a stock LT1 flywheel, but you can't use your T5 flywheel with the stock T56 setup.
Car: `86 SS / `87 SS
Axle/Gears: 3.23:1
Drilled and tapped a large bolt to take an adjustable ballstud. This is mounted in the front adapter plate of the trans.
Bellhousing and front adapter plate are trimmed to clear the fork.
Geometry wise, the fork is in the right position for 78-88 A/G-body or 82-83 F-body mechanical linkage. So except for the VSS, it's a drop-in for a mech. linkage 3rd gen.
el_muerte
Sep 16, 2015 12:01 AM
BlackphantomZ28
Aug 31, 2015 10:29 AM
