t5 flywheel?
Old Oct 6, 2010 | 01:36 AM
superchevy72's Avatar
Car: 86 iroc z black/gold
Engine: LB9
Axle/Gears: 3.42 posi disk
t5 flywheel?
Blown 700r4 in my 88 iroc 350, got a deal on a t5 swap figured it was a good time to do it. Got the trans,pedals,hydraulics lower boot and the console piece for a 5 speed for $100. Only thing I'm missing is bellhousing and flywheel.. so my question is will any standard trans sbc flywheel work for this? I've got a stock flywheel out of my old 4 speed nova that's still in good shape and if I can use it will save me some cash. Idk the diameter or tooth count on it but I can check in the morning before I head to work if it makes a difference..
Old Oct 6, 2010 | 05:33 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: t5 flywheel?
Chances are that it will not work. The early sbc had a two-piece rear main seal. I believe the changeover to the one-piece seal happened in 85, so if your engine is the original, it should be a one-piece rear main. The flywheels are different and not interchangeable, because one is internally balanced and the other is externally balanced.
Assuming that your Nova did not have a later model engine with a one-piece rear main seal, or your 88 iroc did not have an early model engine installed in it, you won't be able to use that flywheel.
Old Oct 6, 2010 | 05:46 AM
89fbirdformula's Avatar
On Probation
Car: 1989 Formula,1991 z28
Engine: 400 Vortec Hsr,496bbc
Transmission: TKO600,TH400
Axle/Gears: 9"4.10, 9"3.73
Re: t5 flywheel?
1pc seal started in 86..
Either way, the older style flywheel will NOT work for the 88 irocs motor.
Ternandes will have a freshly surfaced flywheel/bellhousing here shortly, shoot him a PM and see what he wants for them, they will BOTH work for your application requirements.
Old Oct 6, 2010 | 06:46 AM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Re: t5 flywheel?
Yes, that's true. I only didn't mention it because I don't actually have them in hand yet. I will also have a complete clutch assembly to go with it.
Thanks for looking out for me, 89bird.
Old Oct 6, 2010 | 09:04 AM
On Probation
Re: t5 flywheel?
No problemo man.
If the OP wants them and you guys work out a price/shipping{i get very good fedex discount} i can ship directly to him, just keep me updated via PM or what have you.
Old Oct 6, 2010 | 12:35 PM
Engine: LB9
Re: t5 flywheel?
Thanks for the info guys that was a big help, and I would def be interested in the flywheel and bellhousing. Pm sent.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
