no plug on rear end cover
Old Oct 9, 2010 | 08:13 AM
crowbarmaster's Avatar
Car: 1982 Camaro Berlinetta
Engine: 327 with holley 4bbl
Transmission: T-5 WC
Axle/Gears: 3.42 non-posi
Hello, I bought an 82 camaro recently and I noticed that it makes some light noise from the rear end. our truck always made the same noise when it was low, so i went to check it and there is no fill nut or plug. how would I go about doing this?
Old Oct 9, 2010 | 08:21 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: no plug on rear end cover
should be a plug on the side on the rear near the yoke might be covered in grease and dirt
Old Oct 9, 2010 | 09:37 AM
big gear head's Avatar
Yea, the plug is on the right side close to where the axle tube goes into the center casting. It's a pipe plug and it will require a 3/8 drive ratchet or breaker bar to remove it.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
