gto vs f-body t56
Car: 89 IROC-Z
Engine: 6.2 LS3
Transmission: MN12 T56 GTO
gto vs f-body t56
the 98-02 cmaro vs the 04-06 gto w/6.0 engine
what are the differences in the t56 of the 98-02 vs the 04-06 6.0 gto's?
are the lengths of both the same ?
where the torque are bolts onto the trans in the same location?
is where the crossmember bolts the same?
any other info would be great
Car: 89 IROC-Z
Engine: 6.2 LS3
Re: gto vs f-body t56
oh an are the after market tremec t56's the same as the the 98-02 and 04-06 gto the location of crossmember, torque arm, and the length of it?
Car: `86 SS / `87 SS
Instead of posting once ever 12 weeks on average, if you had searched ls1tech where you also posted this, you'd have had your answer by now.
Yes
Yes
Yes
The offset lever, starter, bellhousing and ratios are different (as long as the GTO box is an MN12 unit.)
Yes
Yes
Yes
Car: 89 IROC-Z
Engine: 6.2 LS3
does anyone know what the part numbers are to make the mn12 use the fbody shifter, 12523298 i belive it this anyone know? and will it fit the gto mn12 t56 so i can use the fbody shifter
98, 9802, body, camaro, differances, differences, fbody, gto, mn12, shifter, t56, transmission, trany, tremec, upgrade
