tv cable help? i think...
Old Oct 30, 2010 | 03:04 PM
palmer90rs's Avatar
ok i have a 90 camaro rs with a 305, all stock car. when im cruisin down the highway and im in the overdrive/4th gear, when i let off the gas it downshifts one gear to 3rd so when i get back in the gas it hits higher rpms and catches then shifts back into overdrive/4th.
is this the tv cable doing that and how do i properly adjust it or fix it?
thanks
Old Oct 30, 2010 | 07:39 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: tv cable help? i think...
How's the fluid color & level?
Done this before?
How fast are you going when you notice it?
Old Oct 30, 2010 | 08:05 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
This should help.http://www.tvmadeez.com/article/index.php
Old Oct 31, 2010 | 04:23 PM
palmer90rs's Avatar
idk it does it around 50 to 65 or maybe more. i cant get that web site to pull up, i use my phone for internet. can someone just tell me how to set it right and i can do it. or possibly tell me if its too tight or too loose causing this
Old Oct 31, 2010 | 06:14 PM
red rock's Avatar
Car: 1987 iroc
Go to the tech. articles on the main page, NOT the faq. They explain how to adjust the TV cable.
Old Nov 1, 2010 | 04:54 PM
Sandslot's Avatar
Car: 1987 IROC-Z Z28 Convertible
Engine: LB9
I'd check the fluid level as mentioned by t-top havoc. Be sure to put the vehicle on a level surface. You might also make sure your electrical and hardware (gov, etc)connections are tight on the transmission.
Old Nov 1, 2010 | 06:06 PM
Sounds to me like it's working perfect.
That's the converter clutch dropping out. Then when you give it a bit of gas again, it re-applies.
Moder transmissions all do that. Some are more noticeable than others, especially in cars with real low-# gears (2.73 and such), like 305 TBI auto cars.
The TV cable has nothing to do with the converter clutch operation; that's controlled by the computer.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
