which Governor 700R4
Old Nov 18, 2010 | 04:15 PM
10mpg's Avatar
Car: '87 IROCZ-28
Axle/Gears: LSD
My trans has always shifted low, WOT shifts are always around 3500 revs often lower and it needs to be really labouring for kickdown to cut in, i've adjusted the TV cable which improved things but not drastically..
Most of the threads on here that seem to point to similar problems, have swapping out the governor as curing it..
It never really bothered me as i have a B&M ratchet shifter installed which i use if i wanna drive hard, but i'd like to get it working properly
Just wondering which one to go for 'corvette spec' seems popular or should i just go for a B&M or similar adjustable one? any makes to avoid or can i just go for the cheapest new one on ebay..?
Old Nov 18, 2010 | 04:19 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Re: which Governor 700R4
what gears do you have now?
I personally went with the corvette governor. I figured since they came with 3.42s from the factory, and I have 3.42s now that it'd be the best starting point.
Old Nov 18, 2010 | 04:31 PM
10mpg's Avatar
Car: '87 IROCZ-28
Axle/Gears: LSD
at the moment lame 2.74's but hopefully upgrading soon....
Old Nov 19, 2010 | 08:43 PM
Pro Built Automatics's Avatar
Is this the original transmission? Has it always done this from the beginning? If you manually shift it, where do you shift it at, at WOT?
Old Nov 20, 2010 | 03:04 AM
10mpg's Avatar
Car: '87 IROCZ-28
Axle/Gears: LSD
No this is a replacement reconditioned trans, it's always done this in my ownership and I believe since the trans was fitted by the last owner..
If i manually shift it usually best point is about 4500/5000 I aim for about 4750 but with the delay after you hit the ratchet shifter it's hard to be accurate..
Also it helps to shift slightly higher when using 100 octane fuel as it pulls noticeably harder and longer when compared to the the cheapy 95 octane stuff..
Old Nov 20, 2010 | 04:43 AM
Tobias05's Avatar
factory tachometer?
Old Nov 20, 2010 | 01:42 PM
10mpg's Avatar
Car: '87 IROCZ-28
Axle/Gears: LSD
Yep...
Old Nov 25, 2010 | 07:05 PM
10mpg's Avatar
Car: '87 IROCZ-28
Axle/Gears: LSD
why does it matter which tach i have? surely the original ones cant be that inaccurate?
Old Nov 25, 2010 | 10:36 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
per my snap 0n modis scanner my tach is off by 800-1000 rpm
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
