Best cooler for built 700R4
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
I've been reading a lot about the coolers for the 700R4s on here and just needed a straight answer. What's the best cooler for my built trans?
The car has a 3000 stall TC, shiftkit, built internals (PO did this so I don't know the details), and 3.73 rear gear. The rest of the car is stock, including the radiator and stock cooling systems, like the oil cooler. One other detail is that I may, in the near future, get a much better radiator and fan for the motor for autoX/drag racing. I'm not sure if that would effect the trans cooler.
Also, my last question is if it will hurt the trans to do a full fluid flush/filter change. The car has 85,850 original miles and I'm assuming the fluid and filter were changed when the PO did the trans upgrades. He mentioned it was 5 or 6 years ago and I just want to make sure because I've heard that transmissions don't like their fluid/filter done early. Thanks in advance guys.
~Matt
~Matt
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Best cooler for built 700R4
Biggest one you can stuff in there will be best. I run an 11x12" cooler (stacked plate design, not tube & fin). Mine is made by Long Tru-Cool.
Absolutely change out the fluid. 5 years is plenty long.
Car: 87 IROC
Engine: LB9
Like this one? I haven't seen one as big as you mentioned yet.
http://www.importperformancetrans.co...4588-1900.html
~Matt
~Matt
Car: 87 IROC
Engine: LB9
Oh here is a bigger one, but still not even close to 11X12". Is it ok if it says it is for trucks? Thanks for the help.
http://www.importperformancetrans.co...4739-1901.html
~Matt
~Matt
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
don't forget a derale tranny pan. It holds an extra 2 quarts and has cooling fins, and a drain plug. I love mine. Nice and sturdy too.
http://www.summitracing.com/parts/DER-14204/
I barely ever tack 150* with my built and stalled auto. B&M cooler, plumbed in series after factory cooler. derale pan.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
