Which flywheel.. 1978 350.. To a 700R4
Old Nov 20, 2010 | 07:56 PM
Kevman's Avatar
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
I have a 78 350, 2 piece rear main.. My old 305 has a 1 piece rear main with the 91 flywheel.. Can I use the 91 flywheel and TC on the 78 engine?
Old Nov 20, 2010 | 08:57 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Which flywheel.. 1978 350.. To a 700R4
torque converter is the same,but you will have to use an'85 -
earlier flexplate as '86 up is external ballance and different bolt
pattern for the hub-IIRC 153 tooth is the right diameter and '79
-85 the year spread as earlier flexplates may have slightly
smaller torque converter bolt holes
Old Nov 21, 2010 | 07:42 AM
Kevman's Avatar
Engine: 2004 LQ4
Right on, thanks.. I was hoping I could save some $$ and reuse my old starter..
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
Gordonr1973
Sep 29, 2015 11:59 AM
6998poncho
Sep 25, 2015 02:56 PM
