TH350 question
Old Nov 24, 2010 | 01:12 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
TH350 question
For sometime now my turbo 350 has been puking up tranny fluid through the dipstick tube. After some research, its of general consensus that the cause is the vent tube being blocked. I crawled underneath the vehicle to inspect my breather tube; only to discover none. Someone has replaced it with a bolt. Is there a reason this would be done?
Old Nov 24, 2010 | 02:53 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: TH350 question
Idiocy?
Old Nov 24, 2010 | 02:58 PM
westman's Avatar
Car: 90 Camaro RS
Engine: 6.3L 383 V8
Re: TH350 question
I have good reason to believe you're are correct. That was my first conclusion.
Old Nov 24, 2010 | 05:07 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Re: TH350 question
OK. Just maybe someone wanted to drive through deep water and didn't want to get water in the trans and didn't think of running a breather tube higher up. But either way I think the first conclusion would apply.
MustangBeater20
Oct 29, 2022 09:20 PM
LittleFranks
Sep 17, 2015 12:22 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
