Built 700r4 problems..I need opinions....
Old Nov 26, 2010 | 03:06 AM
IROCZRickyBobby's Avatar
Car: sho's/camaro
Engine: 406
Transmission: built 700r4
Axle/Gears: 456 gears and full posi
Ok I have a 406 sbc with around 500 hp +/-
Connected to a "built" 700r4
I actually got the engine and tranny together as a package deal.they were in a international scout that had a posi and 373 gears.
The fluid smells looks great and the overdrive cable is adjusted correctly...
I've been driving my car for around 2 months on this combo with no problems
shifted really strong in all gears!
now shortly after installing a quickspool with 456 gears the 2-3 shift seems to be "binding" under full throttle or not "shifting" correctly
when it does shift it doesent slip I think it could be a brake band for 2nd gear maybe.? how much for repair??
What are your opinions and what should I do having limited funds
Old Nov 29, 2010 | 12:40 PM
1981LT1's Avatar
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
Re: Built 700r4 problems..I need opinions....
unforuntely, your description doesn't help much. If your band is slipping you would notice sloppy shifts out of first gear. By changing the rear gears that much, you have drastically changed the operating range of the engine/trans. You may wanna contact some of the high perf trans builders and see what they recommend. It may be just as simple as changing the governor to adjust the shift points.
Old Dec 3, 2010 | 10:15 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
There may be something to that idea because I'm thinking the same thing about mine and I have 4.11 gears. I know there was a big thread about the governor a few months ago. I may need to read through that now. It just seems strange that something that doesn't appear to be tied into the valve body could have such an impact on operation.
Old Dec 3, 2010 | 11:11 AM
1981LT1's Avatar
Engine: LT1; LT1
It may not be attached to the valve body but it controls fluid flow. The valving inside the governor is part of the fluid pressure system, which is what determines when the transmissions shifts.
Hotrodboba400
Dec 10, 2019 07:07 PM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
89newfun
Sep 16, 2015 09:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
