t5 question
Old Dec 6, 2010 | 06:47 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Transmission: auto & t5
t5 question
i got a 89 rs 305 {wc} 5spd parts car. the motor has water in it and the floor is compleatly gone. i took the t5 out and when the fluid dumped out it looked pretty good at first . but after a little bit a bunch of water come out ot the gearbox. the imput shaft by the tail housing turns freely no grinding no noise.
i was wondering if i should put some new fluid in it just until i can get it to a transmission guy to look at it or is this thing just shot. any sugestions?
Old Dec 7, 2010 | 02:43 PM
Bangin Bob's Avatar
Re: t5 question
I have sen alot of those that sit outside with the shifter off and they then get a small amount of water in them. It is amazing how quickly the gears get pitted. Sometimes they can look pretty bad. Just depends how long it was in there? Take the tail and lid off and have a look. Other wise run it see what happens.
Old Dec 7, 2010 | 05:28 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: t5 question
so if the gears are rusted then its no good or could i have it all completly rebuilt?
Old Dec 7, 2010 | 08:16 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: t5 question
Run it in your 92. Change the fluid after running it up to temp. If it makes noise, take it apart.
If it's rusted bad enough to need a rebuild, the gears will be able to be polished and bearings replaced. Not much worse than a standard rebuild.
Old Dec 18, 2010 | 10:47 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: t5 question
i was told to fill up the t5 with desiel let it set for a little bit then drain it and fill it up with new fluid and run with it to see what happens . is this a good thing to do ? i want to make sure all water and bad fluid is out .
Old Dec 19, 2010 | 12:06 AM
jmd's Avatar
jmd
Re: t5 question
It would be okay on a non-world-class model which had brass blocker rings.
It is *not* okay on a world class model due to the blocker ring fibre material.
You won't get 100% of old fluid out with a change. Multiple changes will get most of it out.
Old Dec 19, 2010 | 12:22 PM
usacamaro's Avatar
Car: 92 rs & 89rs
Re: t5 question
cool i am glad i didnt do this yet. thanks man.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
