T5 and T56 Interchangeable Parts?
Old Dec 21, 2010 | 09:38 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
I have an auto car now with a cracked flexplate and have a full WCT5 Swap. Im weighing my options. Pull the auto and just replace the flexplate, or swap to a manual because I love banging gears. If I do go manual, it will be T5 until I can find a T56 at a decent price, or when the t5 blows up, whichever happens first.
My question is what exactly are the parts that will interchange between a T5 and a T56?
Heres a list of the things I would think would change over. All these parts are T5/3rd gen specific. Am I right to assume that these parts will work with the T56?
Pilot Bearing
TOB
Clutch Fork
Flywheel
Clutch/PP
Hydraulics (May need some modification to use in conjunction with 3rd gen pedals right? Shorten the rod?)
Pedals
Drive Shaft
Old Dec 21, 2010 | 04:35 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: T5 and T56 Interchangeable Parts?
Only the pedals and driveshaft will work between the T5 and LT1-T56.
Old Dec 22, 2010 | 05:07 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Or, if you use an LS1 trans and aftermarket adapter plate/ throwout brg. retainer sleeve and new driveshaft and don't mind the shifter further back and add the Cable-X for speedo, you can keep the T5 bell / flywheel / clutch / fork / hydraulics.
(personally, I'd go w/ the LT1 trans.)
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
1nastygta
Aug 8, 2015 07:38 PM
