Transmission fluid
Old Jan 3, 2011 | 01:19 AM
jay173's Avatar
Transmission fluid
Is a full synthetic ok to use in the 700r4?
I want to use Redline D4 ATF.
http://www.redlineoil.com/product.aspx?pid=51&pcid=9
Old Jan 3, 2011 | 08:26 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Transmission fluid
In my experience, I wouldn't run or recommend synthetic ATF unless the transmission (auto or manual) was always run on synthetic since new or rebuilt. Unlike engine oil or gear oil, the ATF has friction properties the enable the clutches to do their job, less about reducing friction. Changing to a synthetic on a trans that already has wear properties of the fluids it been run with for thousands of miles, will either get you nothing, or create problems where there were none before..
My $0.02
Old Jan 3, 2011 | 11:44 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Yeah I like sticking to one fluid also. They say the newer synthetics are better for all transmissions, some manufacturers even call thier fluid "lifetime"....not a believer in that at all.
Old Jan 3, 2011 | 11:59 PM
jay173's Avatar
So what kind of fluid does everyone use?
Old Jan 4, 2011 | 12:08 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
well my transmission is only a couple months old. I run b&m original trickshift. love it.
Old Jan 4, 2011 | 01:24 AM
jay173's Avatar
Is trickshift based on dexron standards for the 700r4?
I normally run redline when I can and in some cars that require special fluids I mix my own so it shifts fast and good. Sometimes people say oh no dont do that but I find 50/50 mix of redline mt90 and redline mtl was the best for most import transmissions that require gear oil. I pulled drain plug during clutch change after 74000 miles there was no wear particals even with the better shifting of the redline non oem fluid.
Old Jan 4, 2011 | 10:33 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
They say it is up to any standards. It also states exceeds type f fluid...ive had no problems.
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Numbah-1
Sep 12, 2015 08:57 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
