Weird noise in rear end (sort of like grinding)
Hey guys, I got an 89 Iroc, car's got 89,000 miles on it. I had a "mishap" with my 2.77 rear end and I found a 3.23 rear end from another 3rd gen. I don't know what that car's mileage was. Anyways, I put it on and ever since I put it on (about 7,000 miles) it's been making a weird noise. Since there was no noise before the swap then I know it's got to be the rear end that I swapped. It sort of sounds like if I was tu put some metal object against let's say my disc brake rotor. It's just grinding. But again it's not brakes. A friend of my told me that maybe my rear end needs to be "adjusted", he said his mechanic told him one time that there are some "adjusters" or something. Anyways I know nothing about rear end and I don't trust mechanics. Any help is appreciated. BTW, should I worry that this things will die on me?
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Weird noise in rear end (sort of like grinding)
Ouch!!
Were the gears checked for pattern on both accelleration & coast?
Bearings checked // replaced? When it was assembled, did you do some figure 8s to get the gear oil dispersed to the bearings?
Is there anything rubbing the driveshaft-- speedo cable, parking brake cable, a piece of miscellaneous something back there that got trapped?
Maybe the best thing to do is pull the cover & see if there's pieces of gears or excessive shavings.
Engine: gone
Transmission: gone
Axle/Gears: gone
Is it mostly when your moving low speed? and after the rear end has been warmed up a bit? (driven)
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
novaderrik
Aug 10, 2015 12:44 PM
