T56 Clutch Hydraulics
Car: 2011 Cummins HO
Engine: 350 HSR
Axle/Gears: 3.43
Has anyone sucessfully used a 3rd gen clutch slave with a 4th gen clutch master and line? I read on another forum that they are the same (specifically a 92 slave) with the exception that the 3rd gen slave has a bleed nipple.. Also looks like the 3rd gen slave has a metal housing.
Seems like it would be a good way to go since I am replacing the slave anyway.
Can anyone confirm this?
Thanks,
Richard.
Thanks,
Richard.
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: T56 Clutch Hydraulics
I might have done this or it was the otherway around, can't remember since it was years ago but It took some modding to achieve. Think I had to drill out the hole little bigger in the slave for the line fitting to fit and maybe swapped the o-ring to, you will know right away when you have them in your hands if it will work or not.
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
the master end will swap to the 4th gen braided line Ive done that. I don't remember if the slave needed a mod or not. but the last slave I used was the metal one from auto zone
bigjay89gta
Oct 15, 2015 08:04 AM
