4th gen posi trac w/disc brake rear in third gen?
Old Jan 20, 2011 | 10:45 AM
kbhughes87's Avatar
I recently found a deal on a fourth gen posi trac rear with disc brakes. i was wondering what is necessary to be able to put under my 87' firebird. is it a direct bolt in that is 1.5 inches wide on each side? or will other things need to be replaced as well?
thanks
Old Jan 20, 2011 | 11:41 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: 4th gen posi trac w/disc brake rear in third gen?
Originally Posted by kbhughes87
I recently found a deal on a fourth gen posi trac rear with disc brakes. is it a direct bolt in that is 1.5 inches wide on each side? or will other things need to be replaced as well?
Welcome to TGO.
Yes. Yes.
The following link should provide the info you require:
https://www.thirdgen.org/forums/tran...-10-bolts.html
BTW, a search on TGO is generally a good idea as there's little that hasn't been asked and answered. Good luck with your project.
JamesC
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
novaderrik
Aug 10, 2015 12:44 PM
