T56 Question (couldn't find answer using the search)
Old Jan 27, 2011 | 09:18 PM
drewmech's Avatar
Car: 1992 Chevy Camaro Z28
Axle/Gears: 10 bolt 3.73 eaton posi
So I got line on a T56 tranny out of a LT1 Corvette. Will this work for my 92 Camaro? No worries on the pedals car came with a manual tranny stock. I know I'll need the LT flywheel, LT starter and the cross member from sphon. Just curious if there is a difference between the T56 that came in a 4th gen Camaro and a C4 vette. Thanks for the help.
Old Jan 28, 2011 | 03:37 AM
Mad_IROC-Z's Avatar
Car: 89 Red IROC
Engine: 5.7
Axle/Gears: 2.77
Re: T56 Question (couldn't find answer using the search)
There is a T56 swap thread in the stickies here. Did that not help?
I can't say about the T56 but I do recall when the T5's were used I believe the Corvettes and F-bodies are the only ones that were the same due to the shifter location.
Old Jan 28, 2011 | 07:06 AM
AFAIK that's not a T-56; it's a ZF.
If so, then no, it won't fit, unless you get one of the bell housings that were used in Firehawks with those. Good luck finding one.
If it looks like this, pass. http://cgi.ebay.com/ebaymotors/Corve...item4cf4bf8170
If it looks like this, your odds are better. http://cgi.ebay.com/ebaymotors/1998-...item3f06dd3896
The T-5 never came in Corvettes so that's not an issue.
Old Jan 28, 2011 | 02:07 PM
drewmech's Avatar
Thanks for the help. Guess thats why I couldn't find anything on this site about trannys from Corvettes. Thanks again
Jeremys87
Jul 14, 2022 09:08 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
redmaroz
Aug 16, 2015 11:40 PM
blackd-out z28
Aug 15, 2015 08:18 PM
antares57
Aug 6, 2015 07:47 AM
