Will it hold?
Old Feb 16, 2011 | 10:19 AM
91_B4C_RS's Avatar
Car: 1991 B4C Camaro RS
Engine: 370 lsx ls3 heads victor jr w/carb
Transmission: TH400 w/brake coan 8"4500-4800 stal
Axle/Gears: Moser 9" locker w/ 4.11's
Will it hold?
91 camaro
383 stroker. Dart heads 850 carb solid roller .606 cam
Turbo 400 trans. With transbrake
3400 STALL
Stock.10 bolt housing 7.5 ring gear
- Moser. 28 spline axles
- Torsen diff out of a 2002 ss
- Richmond 3.73 gears
- Welded axle tubes
26x11.50x16 M/T E.T STREETS.
Old Feb 16, 2011 | 10:36 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Will it hold?
No, time to setup to a 12 bolt or a 9"
Old Feb 16, 2011 | 11:11 AM
big gear head's Avatar
Re: Will it hold?
Probably not. Save the money that you want to spend on the 7.5 and invest it in a better rear end.
RedLeader289
May 28, 2019 01:47 PM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
mattcanty
Oct 12, 2015 11:08 AM
Briandrex
Oct 5, 2015 06:20 AM
racereese
Oct 3, 2015 03:46 PM
