optimum wot shift from first?
Old Feb 19, 2011 | 08:24 PM
Red 87 GTA's Avatar
Car: 87 GTA flame red
Engine: 5.7 l98 cranes 2032 and chip
Transmission: stage 10 700r4
Axle/Gears: 3.27 axle
i did a shift kit in my car hooked everything up and adjusted and it hits 4800ish rpm before shift is that a good number or should it be higher and if it should how do i get there.
Old Feb 19, 2011 | 08:55 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
Re: optimum wot shift from first?
5k is ok for a stock 350 tpi.
it depends on your cam,heads and intake.as those determine your power range.
if nothing wild is done to your motor,then your ok.
you change shift points with the governor,by replacing it,or adding or removing weight from it.i think b&m still sells a kit.
this one is the one used in tpi vettes
http://cgi.ebay.com/ebaymotors/700R4...Q5fAccessories
Old Feb 19, 2011 | 09:07 PM
Red 87 GTA's Avatar
there is a 495/485 lift cam and 10:1 compression. 0-60 was in the mid 5s when it didnt break the tires loose from launch or smoke from 1st to 2nd. i think thats a good improvement i just wasn't sure on shift times or how much i would really achieve from the extra 200-300 revs. also power range is to 5600rpm
Old Feb 19, 2011 | 09:21 PM
regal301's Avatar
Car: 1988 iroc-z
swap the governor out for the one i gave you the link to.right out of the box it should bring you up 3-4 hundred rpm.(5,200 wot) the governor is under a round metal cover,driver side of the trans right before the tail housing.
changing the weights on the governor is trial and error,but would let you really dial in shift points.huge p.i.t.a.
you could verify the gains before the swap by man. shifting the car and see if the motor keeps pulling or starts to plain off.
Old Feb 19, 2011 | 10:19 PM
Red 87 GTA's Avatar
ok ive looked at it but is 5200 a good number for a 2 bolt main then cause ill go with it if it is also i want and at this point have firm snappy shifts does or will this make them musshyer?
Old Feb 20, 2011 | 12:35 PM
regal301's Avatar
Car: 1988 iroc-z
i dont like any more than 5500 on a stock bottom end but there are guys in the engine section that swear by 6200.
Old Feb 20, 2011 | 01:01 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
Mine shifts automatically at 4800 rpm's. I try to hold it for more than that. I am readjusting now caus I just installed a new stall converter.
Pac J
May 17, 2020 10:44 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
